I have a spa that overflows into my 25000 in ground pool.
Water looks ok - chlorine is good (haven't tested in a while) but the water smells a little "stale"
I'm not sure why this is - its "shared" water with the pool and the pool smells ok.
When i heat the spa and use it, i change the valve setup so it only circulates water in the spa (and turns off the pool)
Is there something anyone would recommend to put into the spa water when I'm using it to "freshen" it up a bit?
