Can I just ask do you have to move the actuator to AUX 3 or does the RS do that automatically if you remove anything else already on AUX 3 (like spa blower or lights or whatever)? Then to get Spillover when pool pump is on you also turn on AUX 3? Lastly, why do you suggest only running spa spillover for 30 minutes a day? Why not continuously when in pool mode? Thanks so much for the clarifications and all your posts!Better is to shut off the make up line to the spa and use your existing valve actuator and automation to schedule a Spillover for a couple times per day for 30 minutes or so.
Read Jandy Aqualink RS - Further Reading
