Spa Schematic
Dominic1223
In The Industry
Jul 8, 2019
3
Arizona
I am looking to run a separate pump to run my therapy jets (12 total) and i was wondering if it is better to run it that way and only have the heat coming out of the in floor system or running 1 pump to have heat coming out of the therapy jets as well.
Thank you for any and all advice.
Pumps
Pentair - 3HP Whisperflow (12 Therapy Jets)
Pentair - 3HP VS (Pool / Spa in floor System)
Usually it is better to run with a separate pump but sometimes it wont help. I suspect the issue is with weak jets?
But to help, I need a lot more information.
Flow rate requirements for each jet?
Pipe size to and from spa?
Single pipe runs to and from spa?
Distance from pump to spa?
12 jets is a lot to run off a single pump so unless they are very low flow jets, having a separate pump may not help much.
