- Jan 30, 2023
- 113
- Plaster
- Pentair Intellichlor IC-40
I have an Aspen Spas spa that is 9 years old, tightly encased in a 3 sided stone surround pit. I'm having multiple issues:
1) Leaks. I've had multiple leaks over the life of the spa and have been nursing a very slow one for 2.5 yrs, as pulling the spa out of its stone pit is a major, expensive undertaking (there is a fence a few feet behind the open back end, on a sloping hill; the spa manufacturer's service arm estimated roughly $1k to pull it out, identify and fix the leak). This leak has recently greatly increased--lost ~ 3" in the last week).
2) Rust. In May, I started noticing what I'm assuming is rust accumulation on several of the nozzles (see photo for example). I did convert the tub to salt water with a Saltron Mini in Feb '23. I understand from reading other threads here that this may be heater corrosion-related but not sure.
3) LED lights. The lights are wonky, as they sometimes begin strobing through different colors randomly for no apparent reason. We had them replaced in Mar '21, as critters had chewed through the wiring in the closed-off front of the spa ($900 to pull spa out, replace the lights, repair a leak, etc.). Not a big deal at all, just another thing not working properly.
4) GFCI trip. The GFCI tripped 2 weeks ago for the 1st time since we bought the spa. It has not re-tripped since then.
We've not had to replace the pumps or heater. Water chemistry has been carefully maintained since I began using TFP protocols in Jan '23 but it was spotty at best before then (strips-based chems testing). Don't know how much damage was done prior to switching to TFP.
So, I'm wondering if I might be better off just replacing the whole spa and starting fresh with proper maintenance from the get-go rather than dumping a bunch more money into fixing current and future issues on a spa of this age. Thoughts? Thanks!
