Hi all. I’m currently having an issue that I can’t figure out. We’ve been having to run our spa and pool separately for quite some time. When we purchased the house the previous owner said her pool person could not figure out why the spa was overflowing every time it was in bypass mode. I’ve had a couple guys look at it as well and no one can figure it out. Our goal is to get the spa properly flowing into the pool when the system is in bypass mode so we can turn on the pool pump and circulate the water from the pool into the spa and then back from spa into the pool, creating one nice continuous loop connecting both bodies of water. The spa doesn’t have a waterfall feature that goes into the pool, but it does have two drain lines that appear to be about 2 inches in diameter or less that run from the top upper cubby cutout of the SPA and down to the pool about 2-3ft below the pool surface. I know that these two areas are connected because there’s great water flow/suction from the pool to the spa on these lines when I use the sweeper hose on the pool side sucking water from the spa. Also the spa is about a foot or so above the pool so gravity should help feed the water but nothing mechanical circulates this that could have broke. Nonetheless every time I try to use bypass mode the water comes from the pool and fills up the spa and the spa overflows....there’s no water returning from the spa to the pool.
So because of this we have to chemically treat the two separate and it’s impossible. Here are some pics of the equip/pipes. Any ideas/advice would be awesome!
