- Jul 19, 2012
- 35
- Plaster
- Hayward Aqua Rite (T-15)
I needed to do a partial drain of my pool because of high CYA. I drained about 60% then refilled to where I believe the waterline was previously, a few inches up the tile. My spa is a little higher than my pool and has two waterfall overflows. The valve is set to send some water to the spa and the rest to the pool. For some reason since the refill the spa is only overflowing when the solar turns on. When the pump is low the spa water cannot get high enough to flow over into the pool. This was not an issue before the partial drain. Is this as simple as my water level is too low, or could this be an odd coincidence and I need to replace the spa check valve? Or something else? Thank for any advice on what to look at first.
