My spa light trips the GFI. I can turn on my main pool light with no issues, but as soon as I turn the spa light on it trips. I've taken the light out of the spa and opened it up. There was a bit of moisture inside (dryed/cleaned with a few Q-tips).
I'm guessing I have to replace the whole light which also seems like an issue. Currently, the light doesn't even reach the pool deck. I've tried to see if I have any extra wire in the conduit but I can't pull anymore out. It seems as if the installers put a knot in the wire right before the housing in the niche. I guess I might be able to pull from the junction box instead.
Thanks in advanced for all suggestions!
- Only main pool light on - no issue
- Main pool light on. Spa light on - tripped GFI
- Only spa light on - tripped GFI
- Spa light after cleaning & drying. Put the bulb back in. No cover. Casing dry & above water - tripped GFI
- Took bulb out. No cover. Casing dry & above water - tripped GFI
- Replaced bulb. No cover. Casing dry & above water - tripped GFI
