I have an artesian spa - tropic seas waikiki 864l. This is a stock photo I found, but wanted to try to show where the leak is. Neither the circ pump or the two pumps I can access from this side are the culprit. If you're looking at the side with all the equipment, it is on the side to the right. This side has the step to enter the spa as well as the filters. Trouble is the previous owner built my deck around it in such a way that made access to this side of the hot tub very difficult (they probably thought there was no equipment over there). I for sure cannot get the siding off, but could cut into it. The pump that runs my waterfall I believe is over there and can see it actively leaking when that pump is running. Any tips on the best way to cut into it and/or how do I avoid cutting into something important? I really wish i had a diagram like this, but for that side.
