You can put a filter after the pump and before the heater if you want or combine the systems like shown in the diagram.
Just to be sure, the diagram shows the current implementation. I did it based on the current installation.combine the systems like shown in the diagram
I checked the gas pressure as suggested. The pressure were +3.62" and +0.04" as show the pictures below.You can check the gas pressure at the manifold.
After adjusting the offset pressure screw, the value get around -0.2" (varied from -0.19 to -0.24)12. Remove the barbed adapter. Apply joint compound to the NPT plug and replace to seal the vent port.
@JamesW I saw in the video shared, the pressure was negative with the valve off. Please, let me know if you see something unexpected about this.The pressure were +3.62"
I think that the person had the lines backwards.@JamesW I saw in the video shared, the pressure was negative with the valve off. Please, let me know if you see something unexpected about this.
Below the results of the temperature (according with heater display) in the time. Notes: it was a little rainOk, let's see if the numbers for gas used, temperature rise overall, temp rise for flow and stack temp are all where they are supposed to be.
Here is what the normal exhaust temperature should be:
- Below 250 degrees...very low
- 250 to 290 ..................low
- 290 to 350.................acceptable
- 350 to 480 ..................high
- Above 480...................error/shutdown.
The Stack temperature is in the acceptable zone, which is good.Stack flue temperature
- In around ~3min it get to 333F.
Ok. I calculate assuming two rectangles and the volume get to 2239.71 Liters. Similar to the one reported previously.Are you sure about the spa volume at 580 gallons?
The SPA is uncovered all the time. Just has a metal (tubes) pergola.Note that you will also lose some heat if the spa is uncovered, so that can affect the heating times and it can account for the total heating time being longer than expected.
I will review this implementation further.Inadequate air supply can cause incomplete combustion due to lack of oxygen and the reaction producing some carbon (soot) and some carbon monoxide instead of carbon dioxide.
