STEP 7: Test Gas Orifice Offset Pressure.
NOTE: Test the gas orifice offset pressure with the heater running using a digital differential pressure manometer.
1. Reopen the gas shut-off valve.
2. Test the offset pressure with the heater running using a digital differential pressure manometer.
Connect a tee to the hose from the fan inlet port (see Figure 20) on the blower.
3. Connect a shorter hose from the gas valve vent port to the opposite side of the tee (see Figure 20).
4. The manometer has a positive (high pressure) port and a negative (low pressure) port.
Connect a hose on the third joint of the tee to the positive (high pressure) side of the manometer (see Figure 20).
5. Remove the NPT plug from the gas valve manifold port (labeled “PRESS” “TAP”) and screw in the barbed adapter.
6. Connect one end of a hose to the gas valve manifold port and the other end to the negative (low pressure) side of the manometer (see Figure 20).
7. Start the heater and record the gas offset pressure with the heater running and the gas valve sealing cap firmly in place.
8. Read offset pressure at the manometer.
Measurement should be –0.2 ʺ WC +/- 0.1 ʺ WC
9. If the offset pressure is incorrect, adjust pressure by removing the gas valve sealing cap and rotating the plastic screw using a blunttool, such as a fl at head screwdriver (see Figure 21).
To make an adjustment, rotate 1/4 turn in either direction.
To Increase offset pressure: Turn the plastic screw clockwise.
To Decrease offset pressure: Turn the plastic screw counter-clockwise.
10. Shut down the heater at the user interface.
11. Remove the tee and replace the hoses on the top vent port.
12. Remove the barbed adapter. Apply joint compound to the NPT plug and replace to seal the vent port.
