We have a pool and spa combo where the spa level is higher than the pool. The pump equipment is slightly below the level of the spa/pool
Whenever we go from spa mode to pool mode or pool mode to spa mode, the level in the spa goes down by 1/4 inch. The level is stable as long as we don’t switch modes. As you can see in the picture below, we don’t have a check valve between the pool and the spa and my guess is the spa is draining back into the main pool as it is higher elevation and there is no check valve.
Couple questions -
does this seem to make sense as the cause?
any other thoughts on what it could be?
am thinking about adding a check valve (see drawing below) to stop the flow from spa to pool. Given the configuration we have to add a couple 90 degree elbows and am wondering if that will hurt overall efficiency or whether anybody can think of another solution.
any help would be great appreciated!!!
Couple questions -
