Our swimming pool is several years old and every night the raised spa drains into the swimming pool once the pump which circulates water is turned off. We did some research and were advised it was likely a bad check valve, so we replaced the two check valves in first picture (switch is between the spa and cleaner). The spa continued to drain and so found another post advising a check valve should be installed before the pool pump, and so installed that as well (2nd photo), however, the spa continues to drain to just below the level of seats in the jacuzzi. Our pool is approx. 45 feet long and jacuzzi is at far end away from the pump so don't know if the distance between that and the check valves would have some bearing. We are out of ideas to try. Below are some photos of pool equipment and the spa
