Hi
I ran the spa this morning and shut it off. 30 min later it dropped several inches.
During normal operation, my filter pumps into my spa which overflows into my pool.
I shut off the return to the spa and removed the check valve (see red arrow). No water leaked through the valve.
I left the pool/spa off to see if it would continue to drain. If it didn’t, the check valve would be the culprit.
At the same time, I had to drain my filter to replace the plastic plug on the bottom as that was leaking. Because I had to order a new one, I left it drained.
So the system is essentially open and the return valve to the spa is shut.
I just checked it and It did continue to drain. So something else is causing it to drain or the fact that the system is open is causing it to drain.
I don’t know why having the system open would cause it to drain.
If I’m right, the only other thing that could be a problem, that I can think of, would be the return to the spa in spa mode circled in red. This is an electric valve that turns to shut off return to the pool and diverts heated water back to the spa.
If that valve were leaking, could it cause the spa to drain into the pool?
Any help greatly appreciated!!
Ed
Ed
