Moved from here.
Good morning all....New pool owner here - not trying to hijack your post @n4trombl but I’m having the same issue and was hoping you guys could give me some guidance. Spa has been draining every time pump is off below the return jet. Also when it‘s In normal pool mode without spillover on, the return jet to the spa is sucking water out till it gets below the return then it obviously cant pull anymore water out of spa. I touch the spa return and it sucks my hand onto it and you can here it trying to suck water back in the return. Don’t really think it’s supposed to do that right? I thought if it needed to pull water from the spa it would do so from the drains at the bottom of the spa but what do I know. I’m new to all of this.
Just has someone install 3 check valves this week and thought that would solve the problem but it hasn’t. Something isn’t right apparently. We have also tried to get into the spa twice this week but it never fills up. Jets are on but doesn't fill up so I figured it would fill up with the water from the jets but it doesn’t. The pool return was turned off and no moving water in the pool Water was still.
So far this has been a messand hopefully you guys can help me figure it out since my pb has started other projects and we haven’t seen him in a few weeks. HELP and thanks in advance. @Jimrahbe @Robtown @jimmythegreek
