I've got some cracks in my spa that have gotten larger with time and now the spa is leaking. The cracks extend from the floor of the spa to the concrete pool decking.
I put some red line on the pics that follow the cracks.
I've noticed pieces of plaster missing from in between water line tiles in the spa. Could this be leading to water intrusion that is causing the cracks? Is it more likely a plumbing leak?
It isn't isolated to just one side of the spa, but the pictures are the worse area. The other 2 sides have smaller cracks with no noticeable leaks.
Installer hasn't been much help. They want me to run "Fix a Leak" but I'm pretty sure that I need a lot more than that. Would it be beneficial to patch the grout and put epoxy in the cracks?
South Louisiana, built 2019, 15k gallons, liquid chlorine, variable speed pump, nat gas heater, Pentair equipment.
