Spa controller suggestions
What is this for? Pool? Spa?
A complete description of your setup and some pictures may help us help you.
Good point. It’s for a spa. I added the heat pump, which works well being controlled from the app, but the spa has to be running in order for the heat pump to turn on. I have to keep the temperature on the spa the same as the heat pump to achieve set temperature.
I have been searching to try to find a spa controller that would integrate directly with the Raypak so I don’t have to change temperature on both units.
