I'm at work and just got a call from my wife saying that the spa next to our pool is bone dry with no water flowing in even though the pool pump is running and presumably circulating at least the pool, just not the spa apparently. Any ideas as to the culprit? I'll start troubleshooting when I get home from work, but just seeing if anyone has any ideas to get me a head start. My first thought is a stuck actuator valve or even both maybe....or maybe the check valve is stuck? I've suspected that needed a rebuild, but not sure if a complete blockage at the check valve is even a possibility.
In case it's related, there was a slight overnight freeze last night and the freeze protection function did kick on as I verified last night and this morning. When I checked it before leaving for work, the spa was full though with jets and overflow going.
