I run my automation in pool mode with the spa by pass value open. It appears there is no water returning to the spa via spa bypass when the solar is active. Is this normal? When the solar valve is active the filter runs at 2415 rpms and does not have any water running to spa in pool mode. When the filter pump is running at 1725 rpms with out the solar on I can see a little water spilling over to the pool. I have a spillover mode, but do not want to run that all day. My PH is going up around 7.4 to 8 every 5-7 days already.
Thoughts?
Thoughts?
