I have a problem with my spa that doesn't make sense to me. My pool and spa are on the same filter/ heater system. I control the heated water flow to the spa by manually adjusting the valves when the heater is on. When I turn the heat on for the spa, I close the pool intake valves for the pool drains and skimmers. I also close the return to the pool. So When the heater is on, the intake is only from the spa drain and the return is only to the spa. The filter system should only be pulling and returning to the spa. However when I do this, the water in the pool pump has air bubbles and the water level slowly goes done in the pump. The spa water level also begins to lower. I do not see any water leaks, and the pool was recently resurfaced and the deck was redone. There were no leaks in any of the pipes. I am scratching my head trying to figure out where the water is going and why.
I have two theories as to what may be happening and I wanted to hear from yall to see if I might be right. One, concerning the water level in the spa, there may be a leak in a valve that just allows water to pass on a closed valve? maybe if there is a leak in the return valve that is diverting some of the return to the pool, then maybe all the water is not going back in the spa? I think this is unlikely. Two, concerning the water level in the pump, maybe the pump is too powerful for the single 2" drain? I don't see how this would introduce air into the system, or drop the water level, but its all I can think of. The pump does not seem to be working harder when only the spa drain is open. I have attached two pictures to show the plumbing so yall might get a better understanding of what I am describing. Thanks for any help you can offer.
