@bdavis466 @MyAZPool have been awesome during my build. They always take time to answer my questions and give input. As have you
@kimkats and everyone else on this site. I can not tell you how much I have learned! bdavis and I share the same brotherhood and he and i know what it is like to take pride in your work. His builds show that. That is why i am tackling this huge job myself. I want to be able to finish, look back and say that bdavis loves my pool !!!!!!!!
With that being said..........the wifey is going to be happy! Tile it is!!!! That's just going to open up a whole can of worms when it come to pool finish color!!!!! Kim, you wanted to talk mastic and grout? See if I am on track.....dark mastic - dark grout!
Plumbing Diagram looks great!!! You really have put some thought into this. Thank you.
I don't mind the 3 way at the bubblers, but I am still a little confused on how to "throttle" them with the 3 way? The 3 way at the pump will give me water to the bubblers, but the 3 way at the bubblers will only be able to move water from one bubbler to the other, right? Or am i missing something?
I have a question in regards to the SWG....is there any problem with having the "Chlorinated" Water coming out of the spa jets with direct skin contact? Not sure if the amount is significant. If it might be a problem, should we plumb that on the pool return line only?
Also, If you don't mind - could you plumb in the master temp 400,000 btu propane heater also? Since I have the gas line run already, and the intellicenter is capable of running both the heat pump/chiller and gas heater, I probably am going to order it. This way I think I can use the gas to blast heat the 27,500 gallons and maintain with the heat pump. I think the heat pump will struggle when we hit that freezing south Florida weather!!! LOL
Table top - Definitely Square. And I don't want it to hug the bench. Makes things too tight. I want people to be able to move about in the area. Thought about concrete.....the top of the pedestal is 1" below waterline - so I could drill in steel and bend over, frame it out and pour. But I started thinking - if you have a permanent top - it is going to be right at (or just above) waterline. Lets say my drunk brother (who is 51 years old and 220 lbs) decides to cannonball - or just the fact of kids playing in the pool......causes wave action.....causing any drinks/food on table to get knocked over. Sooooooooo
anyone want to comment on perhaps designing some type of sleeve in the pedestal where perhaps I could have the top extend? Maybe a setting for waterline and another setting like 6" Higher? Of course the top would not be concrete, but maybe a lighter material?
All opinions wanted and appreciated!!!
