new member here, hoping one of you can solve a little mystery for me.
14K salt water pool that stays clear all year long if I can help it, so I'm tending it regularly. It's outdoors among trees, no lanai.
Readings aren't consistent for several things. Salt test kit shows about 4600, AquaRite display shows 5100; the control unit is 20 years old, so ballpark close is okay with me.
Problem #1, occasionally the display will show salt to be 2700, and Low Salt/Check Cell lights are on. The Cell is new, to replace one where readings were also spastic. Thoughts on why this is happening, and WHAT takes the salt reading?
Problem #2, the Flow Switch was replaced expecting readings to stabilize. Different type of switch, and no change in the readings (NOTE: the reading for that were all Low Salt, which is why I added a number of bags and the result was a lot of salt, lol.
When the new cell didn't fix things, I put the old Flow Meter back in and nothing changed, so I put a Rubber Band on the contacts to hold them together, and the gizmo started working the way I'd expect.
Problem #3, this new generator will throw a HOT message from time to time, and our pool temps are in the 60s. WHAT takes the reading for Temp? WHY does the old generator not throw that message (assuming that the Flow Switch is the temp reader, why does one generator cause HOT and the other one doesn't?
Hope this isn't too much too soon, but after replacing the Flow Switch, and replacing the Generator, I'm still getting strange readings?
Sa
Sa
