First time closing new pool up in Westchester, NY. Pool is SWG in ground, 18x36, 3‘ - 6’, Hydrazzo finish, auto safety cover, loop-loc aqua-extreme mesh safety cover, heat pump, auxiliary pump for cleaner, auto fill.
Pool company closed the pool this week. They blew out the lines, put gizmo and anti-freeze in skimmers (2) And put on the loop-loc cover. They had me drain the pool down to almost the second step. I left a pump on the second step.
My questions are:
1- rain and melting snow will fill up the pool. Loop-loc said to leave the pump in the pool to keep pumping the water out but what happens when it freezes up here? The pump and hose will crack. Should I pull the pump out?
2- pool company left the pump and SWG and filter cartridges attached. Should i remove them and bring them inside? The pump has unions but doesn’t look like it has a quick disconnect. The pumps and SWG are Pentair. I believe the SWG has quick disconnect.
3- the auto cover is open so it is all rolled up in the well. Do I need to worry about anything with it over the winter?
Thanks!
My questions are:
Thanks!
