- Dec 17, 2017
- 667
- Fiberglass
- Astral Viron eQuilibrium EQ45
You also are using 3/4 hp worth of money while a vsp is using only what it needs, way less to lift it up
A VS pump is not really optimum for solar heating.
We generally use a VS pump so that we can reduce the speed which equates to reduced cost of course.
With this comes reduced flow but that is not a problem when chlorinating our pools.
However when it comes to heating water, reduced flow reduces the solar system's performance.
Heat transfer is optimum when there is a large delta between the incoming water and the solar collector tubes.
A small temperature rise with a relatively high flow rate is the most efficient way to heat a pool with solar.
If using a VS pump - then the user must take this into account otherwise solar heating performance will be hampered.
So you end up using a VS pump on its higher speeds (when the sun is out) which tends to negate the costs savings somewhat and we are back to square one so to speak.
