When I got my intellicenter in February my solar line was already drained for the winter.
Now that it is warming up in NorCal, I told my pool guy it’s time to use the solar.
He just wants to fill the line and let it run with the filter all summer like it did with old Jandy controller. I thought there would be new programming needed that I was unable to setup (and test) in Feb.
I’m sure just turning it on his way will add heat. However my understanding was with intellicenter you can have it monitor and run the solar so that my gas heater will only have to run if and when the solar can’t get to the temperature desired.
What I’m saying is I thought I had a smarter control now, that could monitor or even predict temperatures and conditions ahead of time, etc. in order to maximize the efficiency of the solar heater and save me energy ($$) regarding the master temp 300.
Also are there times when it’s better to keep the warm water heated on the roof and then dump into pool before swimming? I thought the roof would retain the heat better than an open pool, I could be wrong.
The solar already has an valve actuator installed.
