I'm thinking about adding some solar pool heaters. I have a shower/changing room/bathroom with an outdoor kitchen close to my pool. My pool equipment sits behind the changing/shower room. The roof is flat up on top of the changing room. I'm thinking it would be a nice place to put some solar heaters up on the roof to pump the pool water through to raise the temperature a bit in the pool. The roof is about 10-12ft about ground and i think i have 10x20ft space on top of the changing room. Maybe even a bit more.
What do you recommend in terms of brands for solar heat? How do i calculate how many i should use (or is this a case of fill the roof as full as possible?
It looks like much of the solar heaters are non-rigid and just laying on an angle roof. Mine is flat, is there a base i can buy that give me that angle, or are there any rigid panels that i can buy and build a base for?
At the peak of the summer my pool gets to the 70s, i would love for it to be in the mid 80s
Thanks!
Thanks!
