Hi, we have solar panels (basically like a rubber radiator - not photovoltaic) for our pool on the roof of our house. We have 25+ year old "Solarmetrics" controller that used to work fine and routed water to the roof when the supply water temp was lower than the roof temp (I think that's how it works; there's a temp sensor in the "supply line" and there's a temp sensor on the roof shingles). This year it stopped working automatically (so I have to turn it on in the morning and turn it off in the evening). I don't know if it's the sensors (or the sensor wiring which is looking quite old) or the controller that's failed. Is there a generic way to test the sensors or troubleshoot to try to identifying the issue (I can't find anything a pool solar controller by "Solarmetrics" so I suspect it's no longer in business).
Let us know. Thanks
-- Update --
Thank you so much for all the responses! I'll order a spare sensor just to have one and I'll troubleshoot using the info. (I'm cheap so would rather not replace the controller if I don't have to !!!),
Let us know. Thanks
-- Update --
