- Dec 7, 2014
- 126
- Plaster
- Pentair Intellichlor IC-40
I read what you are saying... I'm just trying to find a law in thermodynamics that would support that.Tl;dr: the greater the difference between the surface temperature of the solar panels and the water flowing through, the more heat energy transferred to the water.
If I add a kilojoule of energy to 52' water, or to 62' water, it is still a kilojoule of energy added.
As long as the temperature sensor in the system is measuring water coming from the large body of water (pool water before either heater) then both heaters will keep adding their respective energy until the solar finally gets shut off.
I can think of a scenario where this can be a problem (which you already pointed out). If the ambient temperature is 70, pool water is 64, and gas heater is heating the water to 74 prior to going out to the solar panels, then the ambient temperature could actually radiate away the heat gains from the heater... I'm just not sure how much this would matter in real use... the solar panels could be programmed to shut off if the differential is 6‐8' less, making this a minimal case.
Certainly not enough in my mind to justify the difficulty in plumbing it this way.
