solar panel temp sensor malfunction
bobby1017
670
Petaluma, Ca
When I checked the temp of the solar panels the reading was 255 deg in the morning, later in the day it was reading 10 deg. The pool people said the sensor was bad, $60.00 later with a new sensor the readings were close to the same 255 deg in the am, then 30 deg when I looked after work. This is an easy touch 8 controller. It has worked fine since 8-11 when it was installed. Any ideas whats up?
