- Jul 29, 2017
- 74
- Plaster
- Hayward Turbo Cell (T-CELL-5)
I will be re-plumbing my pad soon and installing solar. I have a two story roof and live in florida where the solar may shut off during the day with water in the panels allowing the pipes to be exposed to high temps without circulation. I am concerned about vacuum leading to pipe collapse. The header could easily see minus 8 or 10psig. The manufacturer's published install instructions demonstrate no concern about collapse. (They suggest putting the vacuum relief valve at about 5ft above ground) My prospective installer says, "Don't worry about it. Its not an issue." I suspect his real world experience is valid and lets face it... he's the one who will have to repair a collpase. Just the same I am concerned. I am seeking a low pressure pipe to which I can drain my solar. The blower line is convenient.
Is there any reason not to plumb the drain down of the solar to the blower line below, (distal to) the check valve?
I appreciate your thoughts. Thanks again.
PS: The manufacturer and installer have a great deal of experience but to paraphrase Scotty, "They can't change the laws of physics."
