Anyone know where to find a reel for a 27’ round pool? Is seems they only make max 24’. Last yr I joined 2 Rv awning tubes together but have been having sagging issues
Where did you find one at? I've been looking!Good news! They do exist. Found one for $350 shipped.
Cheers
pool supplies canada.Where did you find one at? I've been looking!
I got the rocky reel with 'T' feet like this. I didnt install the wheels and it never budged. I had a 20X40 16 mil cover. The momentum alone from wheeling it on, I can only imagine how tippy the ones with 'n' feet would have been.I don't plan on using the deck anchors but the roller shifts around while in use, then I will do the install and anchor it down to the concrete deck
Thanks very much for your help! You've provided some direction for me to head into; much appreciated.For my needs, I look for a low to the ground (but with enough clearance for the solar cover) and wide base. For my size pool, there is a significant amount of weight from the solar cover while rolling the cover. If the tube is too high or the base is too narrow, the reel could tip over while rolling up the cover or while pulling the cover back over the pool. The Rocky Eazy Roller looks like it will fit my needs. I don't plan on using the deck anchors but the roller shifts around while in use, then I will do the install and anchor it down to the concrete deck. The other consideration was that my wife will do a lot of the rolling alone so it had to be easy to use.
With your smaller pool, something like this may work. Maybe someone with experience with your size pool can provide better advice.
Doheny's In-Ground Pool Solar Reel System, up to 18 ft
