I just had a Suntrek Solar system installed and started up. I have Jandy Aqualink control panel with a connected IQ20-RS.
Question on the programming for the solar. The guy that started up the system said that I just leave the solar on/enabled via my jandy aqualink control, which we setup. He mentioned that doing this would automatically run the filter pump when the solar sensor kicked solar on based on weather. So when he left, my filter pump and solar was enabled. The solar system shutoff in the evening but the filter did not so I turned it off myself.
Do I need to setup a program schedule to have the filter pump run during daylight hours so that the solar can function correctly? And if so, what RPM should I have it run at?
I don't have any experience with solar pool systems and I want to make sure my system is setup properly. Any help is greatly appreciated!
