Solar actuator not working when pool pump is running
Raiderci
3
Florida
I just installed a Pentair EasyTouch PSL4 controller system and the solar panel actuator valve does not open when the pool pump is running. The actuator is plugged in at VLV A location on the Circuit Board. Heat = Solar. What should the Valve be set to? Thanks!
Do you have a solar sensor installed?
See if this thread helps…
R,
I am not sure that the pump has anything to do with the Solar valve turning.
It should turn based upon the system calling for heat. What do you have your heat set-point set for?
Valve A should be assigned to "Solar Active"
Do you have Screen Logic?
