- Jun 18, 2024
- 49
- Fiberglass
- Jandy Truclear / Ei
Whats causing it? Was there a water leak? If whatever caused it is fixed, I’d pack gravel or stone under there. Use a 2X4 to push it in as far as possible and packnit in.View attachment 597442
View attachment 597445View attachment 597446
Tried to reach in with my hand, couldn't get to the end of the hole, but I felt some roots growing parallel to the deck with an exposed part (shown in above picture)
What is away from the pool in that area ? (Far shot pics please) Is water running downhill to that spot or is it coming from the pool deck and not running away as it should ?
I'm thinking I would stuff a few paper towels in there, pulling them out right away to see if they are wet. Then put dry ones back in and run pump on high with max output there (if possible) for awhile and pull the paper towels after a few hours to see again if water is coming from pool or jet. If not, could be many things, including critters, a void in the ground when they poured it that later settled, rain drainage if that's a low point, etc. I too get critters doing that around my home's foundation and the pool deck. Rotting vegetation from former trees & shrubs can also do it. I had a very slowly developing sink hole (1 foot deep x 6 foot dia impression really) that came from a long-deteriorating tree stump the former owner had removed, then planted sod over it. If not finding any new water coming from the pool, I guess to be through you could always dig down more to investigate before filling with gravel then dirt.
Sounds like a good plan, let me try this.I'm thinking I would stuff a few paper towels in there, pulling them out right away to see if they are wet. Then put dry ones back in and run pump on high with max output there (if possible) for awhile and pull the paper towels after a few hours to see again if water is coming from pool or jet. If not, could be many things, including critters, a void in the ground when they poured it that later settled, rain drainage if that's a low point, etc. I too get critters doing that around my home's foundation and the pool deck. Rotting vegetation from former trees & shrubs can also do it. I had a very slowly developing sink hole (1 foot deep x 6 foot dia impression really) that came from a long-deteriorating tree stump the former owner had removed, then planted sod over it. If not finding any new water coming from the pool, I guess to be through you could always dig down more to investigate before filling with gravel then dirt.
