Mr Kenny
My softub has the same problem and I'm going to try the capacitor trick but was wondering since those of you who have done it before (back in 2021) how it it working Now
Thanks
Thanks
BTW I didn’t drain the tub…. You just have to shove a rag or cork the air inlet so water doesn’t come out…
I had the same problem and fixed it by adding these 10×25 capacitors ,it's been 3 weeks no problem. No solder just pushed the legs into the red and black holes. I saw the fix on another thread and tried it and it worked, I ordered the capacitors from Amazon for under 10 bucks. I hope it helpsWe have a 220 gallon Softub recently inherited from the previous owner of our house, and just got it set up and running. The motor is turning off and on frequently and we're looking for advice.
The pump runs continuously as desired until the hot tub reaches the set temperature (100), after that the pump runs sporadically, turning on for a second or two, then shutting off for about 30 seconds, then on again repeatedly.
The display shows "P" when pump is off, and shows "00" when pump is on.
When the pump is running, one or both of the Filter and Heat lights turn on.
Pressing Jets button will run the jets for about 15 minutes, then it reverts to the previous behavior.
It's plugged directly into the outlet so I don't suspect there's an issue with the electrical supply. We tried hitting test and reset on the power cord, and tried unplugging it and replugging it in. Didn't try any more complicated fixes yet. Called Softub and they have a FIVE MONTH waiting list for service "due to the pandemic" so wondering if anyone has tips or troubleshooting ideas!
Thank you!
Jessica & Will
Did you do a video by any chanceI just got a second hand Softub 220 (C-2013 board) with this same issue. Tub would do initial heat up fine but when it's around target temperature, it would turn on for a short time, then off, and repeat maybe every 15-30 minutes. The digital temperature indicator on the controller would fluctuate every second within a range of about 6 degrees. The temperature probes and control panel were replaced by the previous owner to try and solve this issue (which it didn't). I did some troubleshooting with a multimeter and noticed voltage fluctuations across the temperature sensor terminals (red/black). I added a 10uF capacitor on both temperature sensors and that solved the issue instantly. Temperature readings are now stable and correct, tub doesn't turn on/off constantly anymore. Perhaps this can help someone else. I didn't even solder in the capacitors but just shoved them into the holders, so far so good but something more permanent might be a good idea. I'm not sure what is causing these voltage fluctuations, perhaps it's interference from the motor that's not fully accounted for in the board design.
View attachment 366623View attachment 366624
Mind blown right now.. I have been struggling with the same stupid frustrating issue of the turning on and off cycling. Called softub and they said faulty circuit board and i'd have to ship it, pay over 800$, wait almost a year for the new one bc it's on backorder. And they said the circuit board may not even be the issue. Found this post, ordered the little cylinder things from amazon, inserted them per your pic and omg it worked!! I can't even. I'm so excited. I hope this last for a while bc I'm really happy right now. Thank you for this super helpful post! Saved me 790.00$.I just got a second hand Softub 220 (C-2013 board) with this same issue. Tub would do initial heat up fine but when it's around target temperature, it would turn on for a short time, then off, and repeat maybe every 15-30 minutes. The digital temperature indicator on the controller would fluctuate every second within a range of about 6 degrees. The temperature probes and control panel were replaced by the previous owner to try and solve this issue (which it didn't). I did some troubleshooting with a multimeter and noticed voltage fluctuations across the temperature sensor terminals (red/black). I added a 10uF capacitor on both temperature sensors and that solved the issue instantly. Temperature readings are now stable and correct, tub doesn't turn on/off constantly anymore. Perhaps this can help someone else. I didn't even solder in the capacitors but just shoved them into the holders, so far so good but something more permanent might be a good idea. I'm not sure what is causing these voltage fluctuations, perhaps it's interference from the motor that's not fully accounted for in the board design.
Hi, just wanted to thank you for coming up with this simple solution. I ordered a pack of 5 capacitors from Amazon for $6 and installed two of them just like in the photos and they instantly corrected the issue of turning on and off every few minutes all day long. this saved me a costly repair. Thanks again!I just got a second hand Softub 220 (C-2013 board) with this same issue. Tub would do initial heat up fine but when it's around target temperature, it would turn on for a short time, then off, and repeat maybe every 15-30 minutes. The digital temperature indicator on the controller would fluctuate every second within a range of about 6 degrees. The temperature probes and control panel were replaced by the previous owner to try and solve this issue (which it didn't). I did some troubleshooting with a multimeter and noticed voltage fluctuations across the temperature sensor terminals (red/black). I added a 10uF capacitor on both temperature sensors and that solved the issue instantly. Temperature readings are now stable and correct, tub doesn't turn on/off constantly anymore. Perhaps this can help someone else. I didn't even solder in the capacitors but just shoved them into the holders, so far so good but something more permanent might be a good idea. I'm not sure what is causing these voltage fluctuations, perhaps it's interference from the motor that's not fully accounted for in the board design.
