Been adding quite of liquid chlorine from a popular grocery store here in Texas... It claims to be 8.5% Sodium Hypoclorite. When I add the suggested amount to the pool according to my pool math app; the test from my K-2006 test kit shows about 2 or 3 PPM or so lower than what it should read after adding the amount from what Poolmath says. Just trying to figure out what's going on. My assumptions are as follows: I'm not testing correctly, the 8.5% is not real, or maybe the volume of 17,300 gallons of water the the Pool builder says is wrong, or poolmath is wrong. I added some "blue whale" chlorine at 12.5% and getting some better readings from poolmath and what it says to 12.5% of the blue whale chlorine. Just curious about the readings on the jugs of chlorine. Has anyone seen the same on the advertised percent of Sodium Hypoclorite as being misleading??????
