- May 23, 2015
- 25,703
- Plaster
- Pentair Intellichlor IC-60
Well, a brushless DC motor really is "pulsed DC", which really is a form of AC with a permanent magnet on the rotor. If the field were potted properly, it could also work. The control circuits for brushless DC would be a bit more complex than a 400 HZ induction motor, if it were single speed.
In any event, the control unit would need to be changed. I would still stick with 24 Volt in either case.
Yup. More complexity on the control board but a much more reliable motor to drive the unit. It would also allow for variable speed operation of the water pump motor which could be used to optimize the energy use during a cleaning cycle. If they incorporated ultrasonic transducers, the bot could actually “see” where it’s going and know when it’s approaching walls or obstructions. Right now, the robot is “dumb” … it’s essentially a random-walk device. Don’t be fooled by the marketing hype, these robots have no intelligence built into them.
