Thanks, I didn't know that!Pick a spot far from any returnns... consider where you think the lowest amount of chlorine would be? That's a good testing site.
Maddie![]()
Maddie![]()
This is awesome, thanks so much!View attachment 326667
P-o-P. Pool owner patience. Resist the urge to overreact and over correct.Stay the course. You’re doin AWESOME
I am going to test everything again tonight and will post the results here.You might post your test results and list type of pool etc. losing 5ppm chlorine overnight sounds like it’d be a swamp or there’s testing error.
That is very encouraging! We have had similar fights.I think he just doesn't feel confident yet since the pool is new and its our first so he's happy to listen to the local "experts". It's hard when the water looks good but I'm insisting there's still a problem.
It is a false high reading which is why you lowered it before you started. It buys you a week or two during the SLAM when you can't get a reliable PH test. (Anything over 10 FC)PH: over 8.2 but is this accurate with chlorine this high? We got it down to the recommended range before starting the
It turns out my husband kept the box of what was put in the pool during closing. It was an Ameripool pool winterizing kit which contained a gallon of On Guard winter protect algaecide and a quart of On Guard stain and scale preventer.Some questions that may help us further:
- Was your pool closed over the winter? If so, what chemicals were added at closing (antifreeze, algaecide (which type?), any other products)?
- What chlorine product are you using during the SLAM Process
- Poolmath test results are not linked to your profile. Can you post your current FC and CYA?
- Any other products added to the water since opening?
So if I wanted to verify my CYA can that be done with the high chlorine that's in it now?
Thanks. I didn't realize I needed to let the water warm up for the CYA test. I will try again with warmer water.You can add a drop of R-0007 to neutralize the chlorine, I have read in older posts that very high chlorine can indeed interfere with the CYA-test.
Most important thing with the still very cold water is to let the sample warm up to room temperature before doing the CYA-test.
Yes, he put it in the pool. I don't see copper on the label but I'm really not sure what was in it. Ugh.Did he put that stuff in the pool? Does that algaecide contain Copper??
Maddie![]()
Oh my. Thank you, we will get it tested. So if we have too much, we need to drain some of the water and refill?That's a lot of copper. You will want to take a water sample to the pool store and let them test for copper to see how much is in the water. Too much copper will cause stains on the plaster, and will turn light colored hair and fabrics green. Don't let the pool store sell you anything.
Thank you. That is unfortunate and annoying but we'll take care of it!Yes, unfortunately that's the only way to get rid of metals. You could go the sequestrant route, but honestly since the only way copper gets in the water is if someone puts it there, its better to drain and replace water. Once you use sequestrants you have to add them regularly as chlorine breaks them down over time.
My husband ran a sample to the pool store and they tested and said there was no copper. However, they don't know if their test measures total copper or free copper. So are we good or do we need to find a store that can definitely measure total copper?Thank you. That is unfortunate and annoying but we'll take care of it!
