- Jul 21, 2013
- 65,173
- Plaster
- Pentair Intellichlor IC-60
If the true TA is really 25ppm, then your pH would probably be much lower. But pool stores tend to good up the TA test by adjusting the results artificially low. =
As you noted, Pool Stores often report an adjusted alkalinity by subtracting about 1/3 of the CYA, although the CYA is 0 in the test above.
My guess is the TA would test around 60-70 with a Taylor test kit.
TA - Further Reading
