heckofagator
- Oct 6, 2021
- 164
- Plaster
- Pentair Intellichlor IC-40
Received replacement X10 yesterday. So far ran a standard and a fast run. No problems so far! I've determined the fast "F" run is useless. Stops in 1 hr 20 minutes thinking it cleaned the pool. It spends a lot of time on the ramp from shallows to deep. I think the kidney shaped pool with large radii on the bottom confuses its programming. The standard "S" setting does a good job. It seems to get everywhere deep and shallow. Stops at 3 hrs 40 minutes. Charged in same time. Didn't get stuck on drains in either run! Love the filters! Glad it has a 2 year warranty!
They haven't sent me a return lable for the old one yet. It's been turned off with all it's lights on for a week!
Glad you got your replacement, and it’s working fine, I agree with you regarding the “F” fast option, I don’t use it either, gave it a try just to see what it did, won’t be using it again, I charge mine to 7 solid green and select standard “ S” so it just does a 3 hour run on the floor, does a great job picking up the desert debris, I use the ultra fine basket.Received replacement X10 yesterday. So far ran a standard and a fast run. No problems so far! I've determined the fast "F" run is useless. Stops in 1 hr 20 minutes thinking it cleaned the pool. It spends a lot of time on the ramp from shallows to deep. I think the kidney shaped pool with large radii on the bottom confuses its programming. The standard "S" setting does a good job. It seems to get everywhere deep and shallow. Stops at 3 hrs 40 minutes. Charged in same time. Didn't get stuck on drains in either run! Love the filters! Glad it has a 2 year warranty!
Mine good at very fine dust. Make sure the filter is between the 2 ribs. Might make sure the fan is sending lots of water out the top.How good does yours collect dirt and silt? I've run my X11 a few times and it seems to stir it up but not really capture any in the baskets. I've tried both the standard and the fine and both seem to have the same result. My back yard is largely unfinished and my dog loves to swim which means a fair bit of dirt.
You might run OCLT to make sure you don't have algae. Should pick up that stuff.Filter has been between the ribs. I do see the fan move lots of water but usually only when it's doing the walls or turning. Otherwise the fan seems to be a little lazy. Let me try it again today on standard not fast mode and see. For reference, this was in my pool a few hours after the X11 ran on fast mode.
My ultra fine basket picks up pretty much everything, loads of desert dirt, leaves and little beasties, it does a better job than my dolphin S300i ever did.How good does yours collect dirt and silt? I've run my X11 a few times and it seems to stir it up but not really capture any in the baskets. I've tried both the standard and the fine and both seem to have the same result. My back yard is largely unfinished and my dog loves to swim which means a fair bit of dirt.
Greetings! I'm considering to buy a robotic cleaner and seeking for some advice. 1) Between dolphins and smorobt, which one would you recommend? 2) As of cleaning ability,efficiency,quality and design,etc. which way do you think Smorobot would beats a Dolphin? 3) Any problems you met on your X11? Many thanksMy ultra fine basket picks up pretty much everything, loads of desert dirt, leaves and little beasties, it does a better job than my dolphin S300i ever did.
