Does anyone make a replacement smart bulb for in ground pool lights? It's the typical 120v flood. Would like to hook it up to the rest of the smart house stuff.
Thanks
Thanks
I’m planning to go the smart switch route. Have the switch, just waiting to install. But it sure would be cool to do a smart bulb with color changing effects.![]()
Many (most?) of the color LED bulbs for pools change colors or change between programs by turning the switch off and back on. Not sure what type of home automation you have, but should be easy enough to use your HA system to program the smart switch to turn on and off as needed to get the desired effect.
I had an electrician friend come and install a bunch of smart switches I had bought for our new house. He couldn’t install a smart switch for my pool light because there isn’t a power source coming into the switch box. I decided to use the switch elsewhere. Something to keep in mind or check beforehand if you are thinking of getting a smart switch for your pool light.I’m planning to go the smart switch route. Have the switch, just waiting to install. But it sure would be cool to do a smart bulb with color changing effects.![]()
