- Jul 15, 2012
- 636
- Plaster
- Hayward Aqua Rite (T-15)
I have a Superpump housing on my spa pump. I recently upgraded the pump to variable speed (V-green) and notices a few air bubbles in the pump window at slow speed especially. I went to check the drain plugs and the one on the side broke off when I went to remove it. I drilled it out and bought a replacement (actually tried 3 different replacement types) on Amazon. All of the replacements will not get fully tight. They get pretty tight, but when I turn more, the plug gets loose again and can be pulled out. Its like the screw threads are busted. Other than replacing teh housing completely, what are my options? Currently I am running the pump with the plug almost fully tight, and there is no water leaking. However, the bubble issue remains (although there is no guarantee the bubbles are from the drain plug, that is the most likely source from other posts I have read on this site).
