I noticed our pool's rate of evaporation appeared to be more than usual.
After investigating, I found this crack/hole the size of a thumb print on the floor towards the deep end.
It is pushed in a bit and there appears to be another crack through part of the center of it if you look closely.
If you gently tap on it there is a whisp of dirt/sand that comes into the pool. I have not performed a bucket test yet.
There was never any bubble or anything noticeable prior. Just poof, a crack was born.
The floor feels solid/no void noticeable around that area.
No improper items have even been in the pool. It was installed ~13 yrs ago.
Any ideas what could be the cause of a failure like this? I presume even though its pretty small, this is a brace/drain/fiberglass repair job?
