Decoy205
Thanks Kim!...I think it's clothes line rope.Well done! Got a regular production line going there! What kind of rope do you use?
Yes!That should work great! Meant to be outside.
Can we get some pics for others doing above ground closings ?Yes!![]()
Haha...yes they do! I will post pics tomorrow, by the time I saw your post it was already dark out.Can we get some pics for others doing above ground closings ?
They say 1000 words you know.![]()
Nah. That's why we have maths. Lessee here......If I had to guess, it’s pretty close to the weight of a gallon of water.
Thank you sir, I appreciate it!...and thanks for the math!Nah. That's why we have maths. Lessee here......
A gallon is .134 cu ft
A yard of sand (27 cu ft) is 2900 lbs (average)
A gallon of sand weighs 14.39 lbs
A gallon of water weighs 8.34 lbs
So you have the weight of 1.72 gallons of water per jug(plus the water you added)
And WELL done !!!
Thanks Kim! Yes it does, and it pulls on a little wider area than just the one hole.I like how you used two holes to hold them too. That lessens the stress on the holes. Well done!
Google only knows so much. The type of sand used and it's moisture content could put the weight all over the map. And I screwed up with full gallons to your half gallons, so my ammended 7.2 is pretty close to.your 6.6, for guessing through the internet anyways..they are 6.6 pounds each, which is "pretty close to the weight of a gallon of water"...haha
