Slight Water Agitation Affects PH?
revitup
884
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
Should just slightly agitating (vigorously stirring) the water in the container I'm testing affect the PH of that sample?
If you're shaking it so vigorously that you're getting air on the probe it definitely will. I typically swirl the probe around directly in the pool itself. It always stabilizes quickly but if I swirl too vigorously it gets air on it and the value changes.
Chris
I was shaking the PH probe pretty vigorously, value seemed to climb a tenth or two every time I did. I'll modify my procedure to avoid that, thanks for confirming.
