Just ignore the BR part ... the same test can be used to test bromine.
The guide is suggesting you target 4ppm based on your current result, but you would just want to ensure that the OTO is showing a good yellow color (not too light).
I agree it is very hard to read the yellows.
Remember the temp guide is a method to "try to get by". Knowing that if things go bad, it is easy to drain and start over.
Also remember, that having the FC a little high is fine and safe, you just want to ensure that the FC does not drop too low.
