Good morning all
I have been continuing my slam but just got fed up with all the filter cleaning so day before yesterday i installed
a sand filter and i have a few questions about the run time with it. Since you are supposed to run pump constantly
with a slam does this also include a sand filter pump as well?
I can see a ton of difference in the water. It was still cloudy about half way down when i installed. I have run
the pump a total of 6 hours. Kept my shock level at around 18 and gotten in (only the second time) and swirled everything around and
got almost every little stick and twig out from the wind storm two days ago
Water is moving a lot with this 2150 gph pump and i have now noticed that the cap that is on the water output that is inside
the swimming pool will not let me direct the water either up or down like it would before. It is stuck and i wonder if it is because
there is so much pressure on it from the water flowing out?
Do i constantly run the sand filter? Manual says for my pool to only run 2 hours a day. I ran it two hours first day and 4 hours second day..
Stacey
