Good morning guys,
I'm a new(ish) pool owner and struggling to get/keep my pool clear. This will be our 3rd summer with this pool, and we have yet to be able to maintain a clear pool for any significant period. My husband failed to close the pool properly so we started out with a dark green swamp. I'm in the process of SLAMing (for the first time) and this has been my experience. We have a 4400 gallon, 15' Intex metal frame pool, with a brand new SandMaster sand filter filtering 20 GPM and working well.
I’ve been using the following kits to test:
1. AquaChek 541640A Select Refills Test Strip for Swimming Pools
2. Poolmaster 22260 5-Way Swimming Pool and Spa Water Chemistry Test Kit with Case
3. Taylor K-1515-A Drop Test Kit FAS-DPD Pool Chlorine .75oz 1 Drop = .2 or .5ppm (for overnight test, when the time comes)
Tested pool: pH- 7.8, TA- 80, TC-0, FC-0, CYA- 30
Brought pH down to 7.5, and shocked pool to FC level of 10ppm (per pool math) and then brushed pool. I also have been confirming results on both test kits.
I’ve since been checking, adding more chlorine (if levels have dropped) and brushing about 3-4 times per day with slight improvement on color each day. This has been since Thursday evening.
My question is, we have been getting a TON of rain here in MD, and don’t know if I should be doing anything else because of this? I haven’t been testing for anything other than FC/CC since I know shocking can throw off other readings.
Also, how long should I expect it to take to get from the sea form green color to completely clear? It seems to me, from a visual perspective, that the rain has really slowed this process.
