Slamming my pool for the second time are levels ok?
Jun 21, 2017
17
0
Attleboro, MA
#1
HI everyone!
Just started using the BBB method last year, had to slam the pool mid season so I am still very new to this method. I am slamming for the beginning of this season. I can't remember if these levels are ok to slam my pool with.
FREE 40ppm
Combined 80ppm
pH 8.0
TA 80ppm
CH 100ppm
CYA 30
jblizzle
41,193
4
#2
Are those FC and CC numbers correct? Because those are excessively High. Did you forget a decimal place? Or did you use the wrong multiplier for drops? How much water did you use in the chlorine test?
Jun 21, 2017
17
0
Attleboro, MA
#6
Your CH is low for a plaster pool. I'm hoping you just added water for the season which just recently diluted it?
No just a lot of snow and rainwater. I just added some calcium, by tomorrow I will be able to see if it increased the level.
8 x 0.5 is 4 (or 8/2=4) and 10 * 0.5 =5 (or 10/5=5) so it's
FC 4
CC 5.
I bet that has a nice smell to it :)
I retested after I put two more gallons of chlorine. FC 9 and CC 54. I am slamming the pool so by the chart TFP has with a CYA of 30 I should be at a 12 to start and maintain level until it is clear, then do the overnight test to see if there was any loss.
