I opened my pool 4 weeks ago and have been slamming ever since. I cleaned out the dirt and worms and the water was crystal clear. I balanced the water and and started slamming but I can't seem to get rid of the combined chlorine. When I opened the pool it showed 0 cya which is unusual. Usually I have 30-40ppm when I open since I keep it at 70-80ppm for the swg. I added enough cya to bring it up 20ppm and then got a reading of 30ppm. When I checked the cya today it showed that I had 0 so I added enough to bring it up 20ppm.
I'm wondering if maybe I have ammonia in the water. Can you have a crystal clear pool and still have ammonia? Does ammonia cause the ph and alk to rise? I haven't turned on my SWG yet and have just been adding bleach.
Test results:
Chlorine - 10ppm (added a couple jugs of bleach to bring it up to about 22ppm)
cc - 2ppm (cc levels have typically been 1.0 - 1.5ppm)
cya - 0 (added 20ppm)
alk - 90 (it was 70 when I started the slam)
ph - 7.8 (it was 7.4 when I started the slam) - I added enough acid to bring it down to 7.4
calcium - 260
This is what my pool has looked like since I opened it 4 weeks ago.
Test results:
calcium - 260
