I am switching from pool store advice/products to TFP. Opened pool 6 days ago (solid cover though 2 drainage panels). Pretty clear, some fine dirt/silt especially on floor, which has improved with daily cleaning/backwashing. Switched to liquid chlorine this year and adopting TFP. Have been unable to get chlorine levels up even after adding a lot of chlorine. Decided had algae though not much evidnce visually but figured had a lot of organic matter using up the chlorine and decided to start a SLAM after reading from this site. Tested with new Taylor 2006 kit and before SLAM:
Ph 7.4 TA 80 FC 0.4 CC 1.2 CYA 37
I added 3.1 gallons of liquid chlorine today(pool essentials 10% from WalMart) from pool calculator. 4 hours later checked and only had 0.5 FC so added again. I added 2.75 gal chlorine and supplemented with 6 oz of dichlor to equals what the calculator called for (Already used 6 gallons of chlorine which I though would last me longer than 4 hours) After adding this I checked on two K2006 taylor kits as it read 0.5 FC 20-30 minutes after adding second dosing. This did not seem correct to me. Is this poor liquid chlorine or just that much unseen organic material using that much chlorine. I just dont see how I can keep the high doses of chlorine over extended time with these results.. Any thoughts or advice would be appreciated.
